GMcGee Posted September 1, 2023 Share Posted September 1, 2023 Hello, I am looking for a good tutorial video on how to create custom corbels and brackets. I know I have seen some of the videos but after an hour of searching, I cannot re-locate them. Any help is appreciated! Thank you! Link to comment Share on other sites More sharing options...
winterdd Posted September 1, 2023 Share Posted September 1, 2023 I just make polyline solids. Its works great for me. I will say I am a lot faster in autocad with all my CAD work to get the 2d shape and then bring that into CA. Link to comment Share on other sites More sharing options...
MoeGia Posted September 2, 2023 Share Posted September 2, 2023 There are some in the library that may work for you. Or may be a starting point to get exactly what you are after. Link to comment Share on other sites More sharing options...
VHampton Posted September 2, 2023 Share Posted September 2, 2023 Agreed with the replies. Everyone should be familiar with the 3D Solid tool which is invaluable. Making 3d shapes is quite straightforward once you get the hang of it. Here are some steps below. In addition, a CAD file of the bracket so that you can try it out for yourself. That's the best way to learn. All the best. bracket elevation.dwg 1 1 Link to comment Share on other sites More sharing options...
winterdd Posted September 2, 2023 Share Posted September 2, 2023 3 hours ago, VHampton said: Agreed with the replies. Everyone should be familiar with the 3D Solid tool which is invaluable. Making 3d shapes is quite straightforward once you get the hang of it. Here are some steps below. In addition, a CAD file of the bracket so that you can try it out for yourself. That's the best way to learn. All the best. bracket elevation.dwg 116.6 kB · 1 download Straight up gangsta...........Tracing over a pic is the way to go for sure then just scale it to what you want! 1 1 Link to comment Share on other sites More sharing options...
VHampton Posted September 2, 2023 Share Posted September 2, 2023 11 minutes ago, ChiefUserBigRob said: Straight up gangsta...........Tracing over a pic is the way to go for sure then just scale it to what you want! I'll take that as the highest compliment. lol Back in the V versions of the program, the ability to drag .jpeg files from the desktop, and straight into a plan file was ground breaking. It's a neat trick to this day, especially for tracing over floor plans. Link to comment Share on other sites More sharing options...
winterdd Posted September 2, 2023 Share Posted September 2, 2023 2 hours ago, VHampton said: especially for tracing over floor plans. Shhhhhh......we aren't supposed to do that haha. 2 Link to comment Share on other sites More sharing options...
GMcGee Posted October 6, 2023 Author Share Posted October 6, 2023 Thanks everyone! Getting back around to this bracket... CAD is easy to handle on this, now the fun part with CA. augusta column.dwg augusta bracket.dwg Link to comment Share on other sites More sharing options...
GMcGee Posted October 6, 2023 Author Share Posted October 6, 2023 Ok, so I have been toiling with this for over an hour. I don't know what keeps happening. Is there something wrong with the import? I feel like these lines are not closed and its not creating an enclosed shape to make an extruded shape from. column_trial.plan bracket_trial.plan Link to comment Share on other sites More sharing options...
Rpadge Posted October 6, 2023 Share Posted October 6, 2023 You just had a couple of areas with polylines that didnt close. Try this. bracket.plan bracket.plan 1 Link to comment Share on other sites More sharing options...
GMcGee Posted October 8, 2023 Author Share Posted October 8, 2023 Eric, Yes! Very much more comfortable with CAD. Keyboard shortcuts, custom commands, etc. Clearly doing it in Chief is the way to go the 1st time around... Thanks for the detailed help!! Rpbadge, yes, that is exactly what I was trying to do thank you for you much needed help! Link to comment Share on other sites More sharing options...
