4hotshoez Posted February 18, 2015 Share Posted February 18, 2015 I am doing an 11x17 portrait sheet for this project because the plan orientation works best, but not so well for the elevation. I have tried rotating from the DBX, but did not do what I need. Is there a way to rotate it? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 18, 2015 Share Posted February 18, 2015 Todd, Create a CAD Detail from View of your Elevation. That can be rotated and sent to Layout. Link to comment Share on other sites More sharing options...
rlackore Posted February 18, 2015 Share Posted February 18, 2015 Is it rotating the layout box that isn't giving you what you want? ...or is it the portrait orientation of the layout page that is giving you problems? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 18, 2015 Share Posted February 18, 2015 Robert, AFAIK, you can't rotate the Layout Box. You can rotate the Label but not the box itself. Link to comment Share on other sites More sharing options...
Bill_Emery Posted February 18, 2015 Share Posted February 18, 2015 I would use a landscape layout sheet. The plan view in layout can be rotated to get the orientation you want; The elevation can not be rotated if you want to keep it live. Link to comment Share on other sites More sharing options...
rlackore Posted February 18, 2015 Share Posted February 18, 2015 Robert, AFAIK, you can't rotate the Layout Box. You can rotate the Label but not the box itself. Rotated layout box: Link to comment Share on other sites More sharing options...
dshall Posted February 18, 2015 Share Posted February 18, 2015 Rotated layout box: box.png Yep, I was unsure what JC was talking about. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 18, 2015 Share Posted February 18, 2015 Try sending an elevation to layout and then rotate the layout box. Good Luck Link to comment Share on other sites More sharing options...
dshall Posted February 18, 2015 Share Posted February 18, 2015 Try sending an elevation to layout and then rotate the layout box. Good Luck Well, ain't that a pistol, I suppose I never tried an elevation view, thanks JC. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 18, 2015 Share Posted February 18, 2015 Best Answer is Post #2 Link to comment Share on other sites More sharing options...
rlackore Posted February 18, 2015 Share Posted February 18, 2015 Try sending an elevation to layout and then rotate the layout box. Good Luck Just when I think I'm smart, Chief shows me I'm more stupider than I thought. Link to comment Share on other sites More sharing options...
4hotshoez Posted February 19, 2015 Author Share Posted February 19, 2015 Best Answer is Post #2 Yes. and #6 is a good option too, which keeps a "live" connection to model changes. Although they still need updating just as creating a static CAD detail. Thanks. Link to comment Share on other sites More sharing options...
