Wall Niche and Molding on Shower Wall?
DesignGallery
Hi everyone!
I'm trying to draw a shower wall that has a wall niche and tiled molding around the edge of the wall. Right now, I'm using a full height cabinet with a door to show the molding which is blocking the wall niche in the 3D and elevation views. What's the best way to add molding to a wall that allows the wall niche to show? It's the vertical molding that's an issue - horizontal moldings are fairly easy with chair rails. Thank you
