DesignGallery Posted August 25, 2023 Share Posted August 25, 2023 Hi everyone! I'm trying to draw a shower wall that has a wall niche and tiled molding around the edge of the wall. Right now, I'm using a full height cabinet with a door to show the molding which is blocking the wall niche in the 3D and elevation views. What's the best way to add molding to a wall that allows the wall niche to show? It's the vertical molding that's an issue - horizontal moldings are fairly easy with chair rails. Thank you Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 25, 2023 Share Posted August 25, 2023 36 minutes ago, DesignGallery said: full height cabinet Create your own door stile that has an opening between the stiles and rails if you want to keep using this method..otherwise why not use the molding tool to draw in your molding? Link to comment Share on other sites More sharing options...
joey_martin Posted August 25, 2023 Share Posted August 25, 2023 38 minutes ago, DesignGallery said: What's the best way to add molding to a wall With the molding tool. There is one for 3D molding line, and one for 3D molding polyline. Link to comment Share on other sites More sharing options...
DBCooper Posted August 25, 2023 Share Posted August 25, 2023 Wall niches can have a custom molding added as a casing. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 25, 2023 Share Posted August 25, 2023 12 minutes ago, DBCooper said: Wall niches can have a custom molding added as a casing. Got confused by the request as well...the molding in this case is part of a feature and the wall niche is presumed to be much smaller Link to comment Share on other sites More sharing options...
DBCooper Posted August 25, 2023 Share Posted August 25, 2023 You can also offset the casing from the niche. Link to comment Share on other sites More sharing options...
