NewLeafHomeDesig Posted August 23, 2023 Share Posted August 23, 2023 I am starting work on an addition / renovation for a couple who is in the process of buying the home to be renovated. Their realtor has offered to create a 3D model of the house using a service that will scan the rooms. The system can create Matterpak Bundle, E57, and BIM files. Can any of these be imported to Chief, and is it worth doing so? Link to comment Share on other sites More sharing options...
Gawdzira Posted August 27, 2023 Share Posted August 27, 2023 The full Matterpak will not help you as CA can not read the point cloud in the same way Revit can. The floor plan that then give you can be useful but the accuracy is to about 1-2". If you have critical dimensions, I would take those on site. This is based on my owning a Matterport camera and doing multiple scans of spaces. Link to comment Share on other sites More sharing options...
rgardner Posted August 27, 2023 Share Posted August 27, 2023 On 8/27/2023 at 2:37 PM, Gawdzira said: The full Matterpak will not help you as CA can not read the point cloud in the same way Revit can. The floor plan that then give you can be useful but the accuracy is to about 1-2". If you have critical dimensions, I would take those on site. This is based on my owning a Matterport camera and doing multiple scans of spaces. Expand Even though it will not help you with the model creation itself it will be able to be imported as a symbol where you can size it based off of a known dimension and have a full 3d symbol. You can use the slider to cut from the top and get a floor plan you can trace over. You can also use the matterport online model to take measurements to help with your window/door sizes/placements, heights, etc. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 27, 2023 Share Posted August 27, 2023 One other Option is Canvas, if you have an iPad with Lidar ( newer models ) it has its limitations as well but the Canvas Measurement Report (CMR) can be useful on Smaller Projects ( I no longer recommend their Chief output as it is based on X12 only ) it's there PDF of all the Room, Window and Doors Sizes ( get Onsite dims to Confirm while there ) though you still need to make sure you get Ceiling Hgts, and any changes in Elevations, ie step ups/downs and at ALL Stairs ( no# of Risers and Tread Depths are important ). M. Link to comment Share on other sites More sharing options...
rgardner Posted August 28, 2023 Share Posted August 28, 2023 On 8/27/2023 at 5:15 PM, Kbird1 said: One other Option is Canvas, if you have an iPad with Lidar ( newer models ) it has its limitations as well but the Canvas Measurement Report (CMR) can be useful on Smaller Projects ( I no longer recommend their Chief output as it is based on X12 only ) it's there PDF of all the Room, Window and Doors Sizes ( get Onsite dims to Confirm while there ) though you still need to make sure you get Ceiling Hgts, and any changes in Elevations, ie step ups/downs and at ALL Stairs ( no# of Risers and Tread Depths are important ). M. Expand FWIW I have found matterport to be a lot more accurate than canvas. Link to comment Share on other sites More sharing options...
JKEdmo Posted August 29, 2023 Share Posted August 29, 2023 I worked off a Matterport model recently to do a Chief as-built drawing. I struggled with some dimensional discrepancies compared to building exterior dimensions taken from the plat survey. So, I went to their website to read about their accuracy. They claim 1 percent. This can amount to 6" over 50 feet, which is a lot and not extremely accurate. Something to be aware of. Jim Link to comment Share on other sites More sharing options...
Kbird1 Posted August 29, 2023 Share Posted August 29, 2023 On 8/29/2023 at 7:09 PM, JKEdmo said: I worked off a Matterport model recently to do a Chief as-built drawing. I struggled with some dimensional discrepancies compared to building exterior dimensions taken from the plat survey. So, I went to their website to read about their accuracy. They claim 1 percent. This can amount to 6" over 50 feet, which is a lot and not extremely accurate. Something to be aware of. Jim Expand Neither Matterport or Canvas is highly accurate, in my experience, even though both claim 1%, but I I am not sure whether it's "Pilot Error" or just where the Technology is at today. For Client's that use either I highly suggest separate Onsite Laser/Taped Dimensions to Confirm ( see my post above) and to Supply to either company those critical dims. M. Link to comment Share on other sites More sharing options...
