Wall Area
pjames
i calculate a percentage of windows on side property line walls with a couple macros. Because it is "Above grade", I think the only solutions is to draw a polyline (or at least that is what I do). You get the area from the polylline, and then you would need to subtract the windows and doors
if you look closely below you can see the blue polyline that I drew
