Walls are invisible - only windows and lights showing in camera view
jbriarmoon
I've recently subscribed to 15 so I could open a file and work on it.  This v15 is not showing full camera correctly.  I've checked my video card - my mac is relatively new with two video cards and everything up to date, (its using the AMD for CA)
AMD Radeon Pro 5500M 8 GB
Intel UHD Graphics 630 1536 MB
How can I get this to view properly.  I've gone through and checked default settings and everything but nothing works.
I did not find the saved camera view but it seems to be fine on my system and from the windows I think this is the approximate angle.
Not sure what to suggest unless you have another system to test on perhaps see if the other card might be able to generate a standard view for you.  I am not aware of any settings that could actually create that condition unless every plan material was set to be more transparent than glass.  Possibly a tech support case in the morning.
