Solid Railing In Curved Staircase
ChiefDesign2023
  • Build the radial section of rail @ the floor level as a U shape.(Meaning that it has (2) straight sections and a radial outer section.)
  • Place an invisible wall the close off the U. Designate the U shaped room as "Open To Below". This makes it work as its own "room".
  • Build the stairs as one would normally build them.
Aside from Rene's very neat trick.. here's another option...
  • Offset the stair railing (-3) so that it encompasses the stringers.
  • Use the vertical offset option to set the rail "wall" in line w/ B.O. stringers.
This way, it matches your stairs slope.
Hello Everyone,
Thank you again for all your help an recommendations.
VHampton, I am using Chief Premier X14. When doing your step by step process, I do not have the offset option.
Also, when doing the configuration for the railing these are my settings and this is the result.
Aha... suggestion then.
Use Rene's very clever option  OR  make a molding poly-line to match the stair case.
  • Take a 2D elevation and draw a line along the top rail. Convert to a 3D molding.
  • Moldings can have caps added to them.
If you keep this molding below the railing however - no cap required.
  • 3 weeks later...
