JKEdmo Posted August 8, 2023 Share Posted August 8, 2023 Curious, is there a setting that links the print paper size to the drawing sheet size? I'm ping-ponging between 2 projects with 2 different sheet sizes. So, I'm having to manually reset the sheet sizes when I plot. I thought it'd be nice if paper size could be "locked" to sheet size such as with a check box. Thanks, Jim Link to comment Share on other sites More sharing options...
DrawingABlank Posted August 8, 2023 Share Posted August 8, 2023 There is a option in the print sheet setup to 'remember print setting after printing'. Is your checked? You could see if unchecking that allowed the paper to be selected in reference to the drawing sheet. Link to comment Share on other sites More sharing options...
JKEdmo Posted August 8, 2023 Author Share Posted August 8, 2023 16 minutes ago, DrawingABlank said: There is a option in the print sheet setup to 'remember print setting after printing'. Is your checked? I gave that a try, but unsuccessful. That setting appears to be global and when unchecked, the plotter reverts to the system default, in my case Microsoft XPS. Thanks though, Jim Link to comment Share on other sites More sharing options...
Chopsaw Posted August 8, 2023 Share Posted August 8, 2023 1 hour ago, JKEdmo said: I thought it'd be nice if paper size could be "locked" to sheet size such as with a check box. Yes that sure would be nice. Or at least a project specific memory that you only need to set once. Perhaps send that over to suggestions. Link to comment Share on other sites More sharing options...
JKEdmo Posted August 8, 2023 Author Share Posted August 8, 2023 10 minutes ago, Chopsaw said: Perhaps send that over to suggestions. Done. - Jim Link to comment Share on other sites More sharing options...
Kbird1 Posted August 8, 2023 Share Posted August 8, 2023 1 hour ago, JKEdmo said: the plotter reverts to the system default, in my case Microsoft XPS as an aside to this issue.....Make the Plotter your default Printer ( or a PDF Printer ) and delete Microsoft XPS ...at least I am not aware of anyone who uses it or the M$ PDf Printer for that matter.... CP>Hardware and Sound>Devices and Printers> Printers , right click (RC) and make one the Default instead of M$ XPS > RC M$ XPS and delete/remove M. Link to comment Share on other sites More sharing options...
