Corner Windows have a gap
OnlineBuilder2
This is a bug that was fixed in X15.
Before this was fixed, the miter only looked correct in 3D when the side of the window was in the middle of the wall main layer. The simplest way to do this is moving the window into the corner by dragging it well past the end of the wall. You can also use temporary dimensions to get the side to the correct location.
Window side from the main layer outside. Left: 2 3/4", center: 2.1/2", right: 6".
MiteredCornerWindow.plan
