Leadcarpo Posted July 30, 2023 Share Posted July 30, 2023 Hi, for some reason when I build my framing on this plan, not all of the headers show up correctly and it generates a bunch of 1x material on my walls that you can see in 2d and 3d. I'm curious if this is a setting or a layer that needs to be adjusted. I have already tried to remove all of the 1x items from the structural reporting list, but that did not work. I would appreciate any suggestions for this matter, I am currently using X15. Thanks! Link to comment Share on other sites More sharing options...
SteveNovato Posted July 30, 2023 Share Posted July 30, 2023 It looks like some sort of batten trim. Click on these random pieces to determine if they are on the framing layer...they are most likely on another layer that nedds to be turned off in the framing views. Steve Link to comment Share on other sites More sharing options...
DG1949 Posted July 30, 2023 Share Posted July 30, 2023 Maybe a wall layer that is designated as "framing" that shouldn't be? Link to comment Share on other sites More sharing options...
robdyck Posted July 30, 2023 Share Posted July 30, 2023 You have 2 layers in your wall definition assigned as framing. Open the wall specification dialog, select the thin exterior layer and uncheck "Framing" in the Materials Properties tab. Link to comment Share on other sites More sharing options...
Leadcarpo Posted July 30, 2023 Author Share Posted July 30, 2023 Thanks for all of the advice. It was happening because I had checked the framing box in the definition area, thinking I needed to, to use my defaults. It must have sent the wrong message, lol. Link to comment Share on other sites More sharing options...
robdyck Posted August 2, 2023 Share Posted August 2, 2023 Glad to hear you have your issue taken care of. If you get the chance, please check the the post that helped you as solution which will help others! Thx. Link to comment Share on other sites More sharing options...
