Import tools grayed out
itsElaine
Go to solution Solved by TeaTime,
  • Solution
26 minutes ago, Joe_Carrick said:
What version of Chief are you using?
Title Bar says Pro 2024 - so technically you're on the wrong Forum but that doesn't matter, Import options are view dependent.
Open the menu in a Plan view.
That was my other thought.  Plan View has different available tools than Layout.
Chief Premier has a lot more File Export & Import tools than HD Pro.
You can't import any cad, pictures, or other 2d stuff in a camera view (unless it's an elevation).  Also, in the future you might want to post a bigger picture because the one above is pretty hard to see.
