PDF areas wash out on print from layout
beezarton
When printing the layout to PDF, sections of the print are washed out. (see the attached).
Some of this I believe I fixed by avoiding “rich text” and “transparency”, which I stopped using as a result.
Now it seems to also be associated with cabinets which I can’t do without.PDF WASH.pdf
Anyone know the root cause of this problem and what the solution is?
If by "washed out", you mean that the countertop fill is completely hiding the cabinet lines, then this sounds like a problem with the partial transparency used for the fill style.
I have seen some other posts on problems with pdfs and transparent objects.  I think the solution was to try a different pdf writer.  You might want to check out this post to see if it helps you:
https://chieftalk.chiefarchitect.com/topic/12618-mystery-blurry-square-when-exporting-to-pdf/
This tech article talks about printing issues and might also help:
https://www.chiefarchitect.com/support/article/KB-00085/troubleshooting-printing-issues.html
There's definitely something more going on:
but yeah, agreed, go through that article try some other PDF writer software - in the days before chief had a built in PDF Export feature we used to have to use things like PDF995 or CutePDF, sometimes they avoid some of these weird issues.
