LittleWillow Posted May 22, 2023 Share Posted May 22, 2023 (edited) What is the secret to making cabinets line up? When I'm building an island or even placing two wall cabinets side by side they do not line up. The measurements are all the same but the fronts don't line up. This is especially bad when building islands. Is it the countertops? Thanks in advance. Edited May 22, 2023 by LittleWillow spelling Link to comment Share on other sites More sharing options...
TeaTime Posted May 22, 2023 Share Posted May 22, 2023 Things should just snap together - check under the Edit menu, Snap Settings. object snaps and all other options in that section should be checked. It may be helpful to know what software you're using, too - though that's all the same for all titles. You can edit your Signature to include that, helps people know what you're working with. Link to comment Share on other sites More sharing options...
LittleWillow Posted May 23, 2023 Author Share Posted May 23, 2023 Hi, Thanks for your response. I am using X15. Everything is turned on under the snap settings and they still aren't aligning. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 23, 2023 Share Posted May 23, 2023 Use the "Center" tool. In the meantime it will help if you edit your "Signature" as TeaTime suggested - but more like mine. Link to comment Share on other sites More sharing options...
TeaTime Posted May 23, 2023 Share Posted May 23, 2023 Very interesting. Well, Center Object will align them but not snap their corners so they'd probably still have auto fillers or be smooshed into one another - I'd suggest perhaps using Point to Point move, but that relies on snaps, too. But hey, I suppose that's something to test -- if you select a cabinet and use the Point to Point Move tool in the Edit Toolbar, can you snap that to the corners of the cabinets? I'd imagine this issue happens in any plan you work on, right? If its truly Snaps then that's a Preference thing, not a plan thing - but if it IS specific to a plan, I'd definitely recommend posting one here. Otherwise, probably reset preferences. Or call support. Maybe an exorcist. Link to comment Share on other sites More sharing options...
CharlesVolz Posted May 23, 2023 Share Posted May 23, 2023 Try turning off your grid snaps to avoid competing snaps. 1 Link to comment Share on other sites More sharing options...
portfolios Posted June 7, 2024 Share Posted June 7, 2024 Turned off Grip Snaps! Perfect . . . thank you so much! Link to comment Share on other sites More sharing options...
