Run Roof Rafter/Joists Parallel to Baseline?
HumbleChief
Go to solution Solved by TeaTime,
5 minutes ago, GeneDavis said:
You can frame it manually but the rafters are going to be plumb, which may not be what you want.  I find no way to rotate them to have sections perpendicular to the roof plane.
Thanks Gene, the slope is very shallow, probably 1/4" - 1/2":12 so plumb rafters are not a problem and I could have sworn there was a way to do this?  Thanks Again.
  • Solution
This is actually a great use of using Baseline Angle.
In the Roof spec, checking Pitch in Degrees shows the pitch you'd need to use - rotate your roof plane 90 degrees, set it 0 pitch and plug that baseline angle in.
