bthompson Posted May 9, 2023 Share Posted May 9, 2023 I have drawn a house plan for a client with plans to layout. After getting bids back, they want to reduce the square footage in certain areas of the house. For instance reducing the overall width by 16" but taking 8" in two different rooms, and 16" in another in the middle of the house (total under roof 6,000sf). I'm trying to figure out a way to take sections of the house and do a point to point move to reduce the size without having to redraw major sections. Does anyone have a suggestion to do this? Thanks, Burke Link to comment Share on other sites More sharing options...
joey_martin Posted May 9, 2023 Share Posted May 9, 2023 EDIT AREA(ALL FLOORS) tool. 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 9, 2023 Share Posted May 9, 2023 and after selecting via edit area, select transform and replicate and move x or y distance Link to comment Share on other sites More sharing options...
Solution MoeGia Posted May 10, 2023 Solution Share Posted May 10, 2023 To move an irregular shaped area, draw a polyline around the area you want to move, select it, then select edit area (all floors?), transform/replicate and move the desired distance. 1 Link to comment Share on other sites More sharing options...
bthompson Posted May 10, 2023 Author Share Posted May 10, 2023 Thanks for the help! Used your suggestions with a small tweak. I set up a grid with several lines and intersections below the plan for my desired incremental moves and drew the polyline with several "jogs" around the areas of the house to move. After drawing the polyline, I selected "Edit area" - all floors, chose the polyline and made a Point to Point move using my desired grid move. Everything worked well. Afterwords, I only had to reconnect some roof planes and move some windows and doors back to center. Appreciate the input from you all! Burke 1 Link to comment Share on other sites More sharing options...
