Christina_Girerd Posted February 11, 2015 Share Posted February 11, 2015 In X7, I split an upper wall cabinet to have the lower section with glass lites and the upper section with solid doors. My client wants the sections to have different pulls - see attached photo - and I can't figure out how to do that in the cabinet dbx. Any suggestions? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 11, 2015 Share Posted February 11, 2015 Christina, Currently it's not possible with the dbx. I posted a suggestion for that and for different door and drawer faces. https://chieftalk.chiefarchitect.com/index.php?/topic/3848-cabinet-hardware-options/ https://chieftalk.chiefarchitect.com/index.php?/topic/3849-cabinet-front-face-item-options/ Reinforcing those suggestions to CA would be a good idea. In the meantime, your only option is to specify "none" in the dbx and manually place the desired pulls. Link to comment Share on other sites More sharing options...
ArthurDent Posted February 11, 2015 Share Posted February 11, 2015 You could also use two stacked cabinets. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted February 11, 2015 Share Posted February 11, 2015 You could also use two stacked cabinets. +1 Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 11, 2015 Share Posted February 11, 2015 I thought I posted already but it is not showing. If you make one set drawers instead of doors you can get the same look and use different pulls. You won't have opening indicators/door handing but the renders will look right. 1 Link to comment Share on other sites More sharing options...
Christina_Girerd Posted February 11, 2015 Author Share Posted February 11, 2015 Thanks for the tips. I did consider the stacked option, as well as the drawers plus doors option, but wanted to make sure I wasn't missing something first. I will also reinforce the suggestion for allowing different pulls since they allow two different door styles. Link to comment Share on other sites More sharing options...
