SHCanada2 Posted April 26, 2023 Share Posted April 26, 2023 anyway to get rid of this? The walls align per the align tool. the wall widths show the same. wall type is the same 172 Carringham Way NE.plan shows flat ,but you can see the little u shape might be because I changed a foundation wall to exterior wall. but if I delete the wall, draw a new wall and then align to above I get the same thing Link to comment Share on other sites More sharing options...
rgardner Posted April 26, 2023 Share Posted April 26, 2023 19 minutes ago, SHCanada2 said: anyway to get rid of this? The walls align per the align tool. the wall widths show the same. wall type is the same 172 Carringham Way NE.plan 12.15 MB · 1 download shows flat ,but you can see the little u shape might be because I changed a foundation wall to exterior wall. but if I delete the wall, draw a new wall and then align to above I get the same thing When you manually adjust a wall you lose the dynamic aspects of it. Reset the wall to have default top and bottom wall heights. Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 26, 2023 Author Share Posted April 26, 2023 weird, I dont remember changing it, thanks Link to comment Share on other sites More sharing options...
rgardner Posted April 26, 2023 Share Posted April 26, 2023 31 minutes ago, SHCanada2 said: weird, I dont remember changing it, thanks Most people dont remember it because it automatically turns off when you manually adjust the wall. Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 26, 2023 Author Share Posted April 26, 2023 23 minutes ago, rgardner said: Most people dont remember it because it automatically turns off when you manually adjust the wall. I rarely if ever change the wall in the elevation view (which is where I think this is the place it can be done) and I just started this project today which is why it was odd ...but I took a different template today (one i use for floor plans), and sure enough, that wall had it unchecked. I need a test suite for my templates I guess Link to comment Share on other sites More sharing options...
Chopsaw Posted April 26, 2023 Share Posted April 26, 2023 Not likely a template issue as there is no default for that. Walls can also be easily tweaked in 3D by mistake. Not saying that is what happened but it can happen. Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 26, 2023 Author Share Posted April 26, 2023 1 minute ago, Chopsaw said: Not likely a template issue as there is no default for that my template has 4 walls in the basement, main floor and second floor. When i start a project, first thing I do is adjust those walls to match the design. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 26, 2023 Share Posted April 26, 2023 Just now, SHCanada2 said: my template has 4 walls in the basement, main floor and second floor. When i start a project, first thing I do is adjust those walls to match the design. Yup, definitely check the settings on those then. Link to comment Share on other sites More sharing options...
