mcrump Posted February 7, 2015 Share Posted February 7, 2015 When you folks design a home with a slab foundation, how do you set up your defaults? Do you include floor finishes or do you not worry about such stuff. By the way, this is simply directed at depicting sections. Thanks! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 8, 2015 Share Posted February 8, 2015 I add floor finishes but they are all a 1/2" so its easy to figure out heights without thinking too much. The problem with some sections is the floor to ceiling manual dimension will pick up the finish, then I have to zoom in and move it. Also if you turn off floor finishes in section view, you also lose the floor sheathing. Link to comment Share on other sites More sharing options...
joey_martin Posted February 8, 2015 Share Posted February 8, 2015 As you and I discussed on Saturday, I think it would speed things up for you to have a slab template separate from a crawl template. The only reason I don't have a different template for crawl vs. basement is because they are so similar. If I did more slab homes, I would have a template for them. Link to comment Share on other sites More sharing options...
mcrump Posted February 8, 2015 Author Share Posted February 8, 2015 Yep, I'm setting one up for slabs and one for crawls. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 9, 2015 Share Posted February 9, 2015 I used to set up different templates for every condition, but later on I found its just too difficult to update them all as you go, so now I just use a very basic template and just change it to what I need. Much simpler for me, when I find something that needs changing, and that happens a lot as you go until its good to go. Link to comment Share on other sites More sharing options...
dshall Posted February 9, 2015 Share Posted February 9, 2015 I used to set up different templates for every condition, but later on I found its just too difficult to update them all as you go, so now I just use a very basic template and just change it to what I need. Much simpler for me, when I find something that needs changing, and that happens a lot as you go until its good to go. Amen brother Perry. We can spend countless hours setting up templates for different scenarios or you can spend 32.7 seconds changing the default template to work for the condition at hand. I and I am assuming Perry, quickly switch from MONO SLABS to RAISED FLOORS or CONVENTIONAL ROOF FRAMING to TRUSS FRAMING or ......... one template is all you need.... you can quickly change it for your particular project. Link to comment Share on other sites More sharing options...
bernie Posted February 9, 2015 Share Posted February 9, 2015 anyone got a template successfully working for a mixed model . e.g. with mono slab floor (garage) connected to a raised pile floor with piles around perimeter (not stem wall around perimeter)? both floors at same height so yes there is a digout or ground sloping to accomodate the crawl space / ventilation requirements etc. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 9, 2015 Share Posted February 9, 2015 That would be a standard raised floor template. I don't include a floor in mine. leave it blank until I know what it is. That plan you have would not be a standard type. Link to comment Share on other sites More sharing options...
