BruceKC Posted March 16, 2023 Share Posted March 16, 2023 I'm not sure whether this is the place to report an issue with x15, so please direct me elsewhere if needed. In X15, on occasion when I select an object and try to open it, Chief locks up my computer for 10 or 20 seconds and then opens a dozen or more camera views that have never been there before. Once they're all available to delete, I can do that and then open the object, but I have no idea how to keep this from happening. It's weird. Link to comment Share on other sites More sharing options...
MPDesign Posted March 16, 2023 Share Posted March 16, 2023 I would send it to tech if you can get it to reproduce the problem. Is this a default x15 plan template? or a plan started in previous version? Link to comment Share on other sites More sharing options...
BruceKC Posted March 16, 2023 Author Share Posted March 16, 2023 New plan started in x15. It's sporadic so probably not reproducible. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 16, 2023 Share Posted March 16, 2023 11 minutes ago, BruceKC said: New plan started in x15. It's sporadic so probably not reproducible. Please send any glitches to tech support, that's what the public beta phase is for. Thanks Link to comment Share on other sites More sharing options...
Dermot Posted March 16, 2023 Share Posted March 16, 2023 Please report any and all problems directly to our tech support team, regardless of whether you are using X15 beta. More info about reporting problems can be found here: https://www.chiefarchitect.com/support/ That said, I have never heard of such a problem before. I really can't think of a scenario where trying to use "open object" on something like a cabinet in a plan view would actually create any new camera views. I would first try the most obvious things like rebooting your computer and if that doesn't solve the issue then you might want to try an uninstall and reinstall. You should also probably run a virus scan. If none of that seems to help, then definitely contact tech support and they might have some better ideas on what to look for. Link to comment Share on other sites More sharing options...
