Editing below grade lines
badriver
So if you are using "edit active view" from a plan view, you will not have the new "below grade" page in the dialog.
If you use "edit active view" from your open elevation view, you should.
Also, if you just select all of your elevation cameras in plan view, you can use "open object" and you should see "below grade" on the camera dialog.
If this doesn't help, then you should really post a picture of what you are seeing or contact tech support for more help.
