emac60 Posted March 7, 2023 Share Posted March 7, 2023 I am having trouble deleting the overhang in front of my shed dormer. I am going to have a cantilevered deck with a patio door. I tried creating an additional "hole" in the roof plane, and it draws just as a hole through my sliding door. This is a non exploded auto floating dormer. The overhang goes away, leaving a "hole" across the face of the siding and doorway. (pic below) I searched the tutorials and forum... no luck. thanks so much Ed Link to comment Share on other sites More sharing options...
Gawdzira Posted March 7, 2023 Share Posted March 7, 2023 This does not look like a good candidate for a floating dormer. I would build that with walls and roof planes. 3 Link to comment Share on other sites More sharing options...
Doug_N Posted March 7, 2023 Share Posted March 7, 2023 2 hours ago, emac60 said: I am having trouble deleting the overhang in front of my shed dormer. I am going to have a cantilevered deck with a patio door. I tried creating an additional "hole" in the roof plane, and it draws just as a hole through my sliding door. This is a non exploded auto floating dormer. The overhang goes away, leaving a "hole" across the face of the siding and doorway. (pic below) I searched the tutorials and forum... no luck. thanks so much Ed This should be easy to do by manually adjusting the roof perimeters. Post a plan and I will have a go at it. Link to comment Share on other sites More sharing options...
emac60 Posted March 8, 2023 Author Share Posted March 8, 2023 Ok, here it is ICF 28 x 38 Garage.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 8, 2023 Share Posted March 8, 2023 I agree with Alan, this should just be done with walls and roof planes. Having said that, I would start by exploding your dormer. Then convert the hole in your lower roof plane to a standard polyline. Then select that roof plane, click the polyline subtraction tool, and then click on the polyline that used to be a roof hole. Link to comment Share on other sites More sharing options...
Doug_N Posted March 8, 2023 Share Posted March 8, 2023 I exploded the dormer. Then manually adjusted the roof following the suggestions that Eric made. I duplicated this in X-15 and had the same results. Perhaps you should contact tech support and report this as a bug. Link to comment Share on other sites More sharing options...
emac60 Posted March 24, 2023 Author Share Posted March 24, 2023 thanks for your help! this all worked once I drew the back dormer manually. 1 Link to comment Share on other sites More sharing options...
