DRyeHD Posted March 3, 2023 Share Posted March 3, 2023 How do I go about putting a roof on this round room only? I've watched the related video and done some searching on line. When I use the Build Roof Planes and try to retain manually drawn roofs (which all other roof planes are) CA puts auto roof planes on top of all the other roof planes. Link to comment Share on other sites More sharing options...
Solution Chopsaw Posted March 4, 2023 Solution Share Posted March 4, 2023 You could always copy that round wall over to a blank plan and auto build there and just CTRL + ALT + V back a forth until it looks good. Depending on how many sections you use you may want to trim the overhang to get a smooth fascia. It is just a (roof) polyline. 06 Options Enter the Segment Angle at Curved Wall, which is the angle for roof segments automatically generated to cover a curved wall. A smaller angle produces more roof planes. Note that in some instances, slightly smaller or larger values will be used instead of the specified angle. Link to comment Share on other sites More sharing options...
DRyeHD Posted March 4, 2023 Author Share Posted March 4, 2023 Wow, why didn't I think of that! That will work. Thanks so much. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 4, 2023 Share Posted March 4, 2023 make sure you also check "mark as edited" at any roof planes you want to be left unchanged. Link to comment Share on other sites More sharing options...
