Flagstone - Custom Texture
Ange822
Go to solution Solved by Ange822,
Good afternoon,
I'm looking for a way to change a texture image. Not sure if there is a free photoshop type of program that can be used.
I would like to achieve the flagstone with a Natural Red / Brown Granite texture, and the fill between to be a Gravel texture.
thanks in advanced!
Last month another Chief user posted an amazing tool he found for creating stone textures.  It is pretty easy to use and customizable.  Your custom texture looks fantastic, but this tool could also come in handy.  :)
Hi Susan - thank you so much for sharing!! That is helpful. It's so nice to see some of these tools be shared :)
Could almost use the Stone Curator Designer for Tile Designs as well to a certain extent!
I found a website shared in another Topic that helps make a texture / image seamless. So if you have a picture of a texture from a website, it doesn't seem as "blocky" or "tiled" when copied / pasted. https://www.imgonline.com.ua/eng/make-seamless-texture.php
3 hours ago, Ange822 said:
Thank you very much. I have downloaded it and was able to get a similar outcome. I'm sure it will take me a while to figure out how to use the program proficiently.  :)
You're welcome! I was a long time Photoshop user in another life, and yes, it's quite different. :)
Hi Angela,
Thank you for sharing this tool to make seamless textures.  This is going to be great!
One thing to mention:  Do not click on the big "START" button.  That takes you to a page to pay for content.  Just follow the directions on the page, import your image and adjust.
Susan
Hey Susan, I was looking for another tool to make my own stamped concrete that looked like wood, I came across another free program almost identical to what you had shared with me, but it has different patterns / and wood or tile materials instead of all stone. With most things, not everything is free, looks like there are some textures and the options to actually import your own material but would require the "pro" account for $100 / year. Might be useful anyways :)
https://architextures.org/
Hi Angela,
Thank you for the link!  I will check that one out.  Have you tried Substance Player?  I've used it quite a bit for creating custom tile and it can also be used for custom wood and custom fabric.
Susan  :)
