CarlosConsejo Posted February 28, 2023 Share Posted February 28, 2023 Hello, I'd like to know if there is a way to see materials in 3d cutaways as solids. For example I want to see studs as a solid, not as a 6 plane object that i can "see through". The same with beams, sheathing, etc. Thanks in advance for the help. Link to comment Share on other sites More sharing options...
Michael_Gia Posted February 28, 2023 Share Posted February 28, 2023 1 hour ago, CarlosConsejo said: Hello, I'd like to know if there is a way to see materials in 3d cutaways as solids. For example I want to see studs as a solid, not as a 6 plane object that i can "see through". The same with beams, sheathing, etc. Thanks in advance for the help. Especially the terrain. Would be nice. At the moment you will only see the terrain cut fill if the camera is outside the terrain in an elevation. Maybe, I’m wrong but Chief does not have a proper “cutfill” feature like other softwares do. What we have is the almost useless, Autodetail tool. 1 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted February 28, 2023 Share Posted February 28, 2023 2 hours ago, CarlosConsejo said: Hello, I'd like to know if there is a way to see materials in 3d cutaways as solids. For example I want to see studs as a solid, not as a 6 plane object that i can "see through". The same with beams, sheathing, etc. Thanks in advance for the help. One of the first suggestions ideas I had about the 3D cutaways. If they were shown as solids then the detailing would be epic with those 3D cutaway shots used in details. But alas, not happening. 2 Link to comment Share on other sites More sharing options...
CarlosConsejo Posted March 1, 2023 Author Share Posted March 1, 2023 Thanks Michael and HumbleChief, is there any workaround you know about? Thank you! Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 1, 2023 Share Posted March 1, 2023 1 hour ago, CarlosConsejo said: is there any workaround you know about? I don't know of any work around. You could build framing and carefully place and drag various studs and floor joists so they are positioned in such a way that your section is just in front of those framing members. So floor joists would have to be parallel to the section cut, etc... Link to comment Share on other sites More sharing options...
MPDesign Posted March 2, 2023 Share Posted March 2, 2023 I made this from a 3d framing view and some solid layers applied in elevation, notes added in 3d view, with 3d arrows from the library. it took about an hour fussing. 1 Link to comment Share on other sites More sharing options...
DrawingABlank Posted March 2, 2023 Share Posted March 2, 2023 Not sure if you found this thread but it may be a help. Unfortunately no direct answer but it does include a few more ideas that may work for you. Link to comment Share on other sites More sharing options...
