Matt-LaForge Posted February 22, 2023 Share Posted February 22, 2023 I can't seem to find a way to correct a possible default as my walls are showing as 24 on-center and all framing settings in General Framing Tools have been set to 16 OC. My roof framing is correct, but not the walls. Any ideas? Link to comment Share on other sites More sharing options...
GeneDavis Posted February 22, 2023 Share Posted February 22, 2023 Look at your wall definition framing layer. One can choose 16 or 24. If you drew a wall with its framing done with a 24 center, that is what you will get. But why not 24? Most of the time in my area with a 15 degree F winter design temp, I cannot make my ResChecks unless I go to 24. And edit your signature in your profile to show that version of Chief Premier X or whatever you are using, plus what you run it on. It helps us all better sort out your problems. Link to comment Share on other sites More sharing options...
DBCooper Posted February 22, 2023 Share Posted February 22, 2023 Or check out this tech article: https://www.chiefarchitect.com/support/article/KB-00907/specifying-the-on-center-oc-spacing-for-wall-framing.html Link to comment Share on other sites More sharing options...
Matt-LaForge Posted February 23, 2023 Author Share Posted February 23, 2023 17 hours ago, GeneDavis said: Look at your wall definition framing layer. One can choose 16 or 24. If you drew a wall with its framing done with a 24 center, that is what you will get. But why not 24? Most of the time in my area with a 15 degree F winter design temp, I cannot make my ResChecks unless I go to 24. And edit your signature in your profile to show that version of Chief Premier X or whatever you are using, plus what you run it on. It helps us all better sort out your problems. Thanks. It is all set at 16 but wasn't originally. Looks like I need to be rebuild all my exterior walls, huh? I just rebuilt one as a test and it still came up at 24" OC. I chose 16 OC as I want my wall framing to match my rafters. I'm in zone 5 and need R49 in my cathedral ceiling, driving me to 16 OC. Thanks for your input. Link to comment Share on other sites More sharing options...
Matt-LaForge Posted February 23, 2023 Author Share Posted February 23, 2023 17 hours ago, DBCooper said: Or check out this tech article: https://www.chiefarchitect.com/support/article/KB-00907/specifying-the-on-center-oc-spacing-for-wall-framing.html Great article. Thanks. I did those before I saw the article (I looked for it, I swear) and I still can't get it to work, even on a newly built wall. Looks like I can't modify once the wall is built, but why I can't get new walls to follow 16 OC like my roof is odd. Thanks, again. Link to comment Share on other sites More sharing options...
Matt-LaForge Posted February 23, 2023 Author Share Posted February 23, 2023 Not sure why, but it works now. I must've done something wrong initially. Thanks for all of your help! Matt Link to comment Share on other sites More sharing options...
basketballman Posted February 23, 2023 Share Posted February 23, 2023 Go to wall definition and you will see the ability to select 16' or 24" This seems to override other options . Link to comment Share on other sites More sharing options...
