HumbleChief Posted February 22, 2023 Share Posted February 22, 2023 Is there an auto setting to get the walls to fill in above exposed rafter tails? Or is it necessary to pull up each wall manually? Link to comment Share on other sites More sharing options...
Chopsaw Posted February 22, 2023 Share Posted February 22, 2023 I guess it depends on what you are going to show in your documentation but I think a manually drawn attic wall would be a lot more compatible with most situations. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 22, 2023 Author Share Posted February 22, 2023 Thanks Chop but that didn't seem to work? Tried it on a couple different test plans with no love. Have you had this work? Link to comment Share on other sites More sharing options...
Chopsaw Posted February 22, 2023 Share Posted February 22, 2023 That was just off the top of my head, so possibly not. We went over that exact situation in one of Scott's webinars about 5 years ago though and had it working somehow. If I have a moment I will see if I can find it. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 22, 2023 Share Posted February 22, 2023 I could not find the original posting but here is the video: About half way through Scott sets the sub fascia to 0 but I don't think that takes care of the proper wall framing.... Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 22, 2023 Share Posted February 22, 2023 Did you try some rafter blocking there? Either turn it on in framing or add iit manually. the plate height and walls should stay the same height. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 22, 2023 Author Share Posted February 22, 2023 3 hours ago, Chopsaw said: I could not find the original posting but here is the video: About half way through Scott sets the sub fascia to 0 but I don't think that takes care of the proper wall framing.... Thanks Chop. Found the info at 1:17:45 but can't get the settings to affect X14 in the same way. Perhaps it worked that way in X10 as in the video? Dunno but the roof rafters don't show when using the same settings in X14. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 22, 2023 Author Share Posted February 22, 2023 It all looks OK as in the walls build to the 'soffits' but the rafters don't show. Interesting? Dunno. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 22, 2023 Author Share Posted February 22, 2023 2 hours ago, DRAWZILLA said: Did you try some rafter blocking there? Either turn it on in framing or add iit manually. the plate height and walls should stay the same height. Walls frame up to the sheeting (or soffit in this case) OK using your and Scott's technique in the video that Chop found but the rafters don't show. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 22, 2023 Author Share Posted February 22, 2023 Here's the plan file I'm playing with. WALL FRAME 1.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted February 22, 2023 Share Posted February 22, 2023 Have a look at the framing view Larry and you will see what is happening. Turn off "Trim Framing to Soffits". Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 22, 2023 Share Posted February 22, 2023 CHOP IS RIGHT. Link to comment Share on other sites More sharing options...
