SHCanada2 Posted February 11, 2023 Share Posted February 11, 2023 I'm trying to show the perspective camera on the plan view in layout, but it will not show. it shows perfectly fine on the plan view in the plan any ideas, seems like a rather simple thing? The normal elevation callouts show just fine. Must be something simple. If I change the camera specification to show as callout it will show on layout, but I would like to show the field of view, and the callout does not shopw the field of view Is this possible (other than "as image")? callout Link to comment Share on other sites More sharing options...
joey_martin Posted February 12, 2023 Share Posted February 12, 2023 check your layer set attached to the plan view. Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 13, 2023 Author Share Posted February 13, 2023 hmm, not sure if I understand, if I change to a callout in the camera specification it changes to callout on the plan, and then the callout shows up on layout. But if I leave it showing the camera and not the callout, and If i change the layerset to all on, it still does not show the camera on the layout, but shows on plan Link to comment Share on other sites More sharing options...
Kbird1 Posted February 13, 2023 Share Posted February 13, 2023 On 2/13/2023 at 12:28 AM, SHCanada2 said: If i change the layerset to all on, it still does not show the camera on the layout, but shows on plan Expand Did you "refresh" the Layout View? text and dimensions refresh auto pretty quickly , other things may not...... PS I have not tried this myself , just thinking out loud M. Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 13, 2023 Author Share Posted February 13, 2023 there is no refresh for plan views that I see. I did try linking and unlinking. no difference. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 20, 2024 Author Share Posted May 20, 2024 I'm trying to do this again, and same problem. Is the only option to screen shot the plan and put it on layout? Link to comment Share on other sites More sharing options...
