ValleyGuy Posted February 1, 2023 Share Posted February 1, 2023 Is there a way to display 'Main Layers Only' for ICF in an efficient manner? I see that there has been a few discussions in the past describing a few work arounds to temporarily display the foam block for a quick picture, however, there seems to be a lot of work involved and has to be done multiple times if one wants to move / adjust anything. Has Chief put in a reasonably easy way to shed off the interior layers (drywall) and exterior layers (siding) to ICF walls and foundations? 'Main Layers Only' appears to be triggered by wood framing and not the actual 'Main Layers' of the wall in both 3D and Elevation cameras, and ICF doesn't seem to have a way to "frame" a substance to become visible. My goal is to show the overall ICF scope of work in 3D as well as show wall elevations to help the foundation contractor see the few different areas that need further explanation - just like we would with wood framing elevations. I've been making CAD elevations, but that too is very time consuming. Link to comment Share on other sites More sharing options...
robdyck Posted February 1, 2023 Share Posted February 1, 2023 Main layer only doesn't apply to 3d views. Your best bet is to make a copy of the plan file and remove the unwanted layers from the ICF wall, just for the purposes of those 3d camera views. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 1, 2023 Share Posted February 1, 2023 I have messed around with a very similar situation of a wall framed on top of a couple of courses of CMU that looks really strange in a framing view without the concrete blocks visible. Ideally you would assign the things you want to show in a framing view as framing but that just leads you into a huge mess. I think I ended up making a duplicate that I could put on it's own layer which could be turned on and off as necessary. Link to comment Share on other sites More sharing options...
tundra_dweller Posted February 2, 2023 Share Posted February 2, 2023 1 hour ago, Chopsaw said: I have messed around with a very similar situation of a wall framed on top of a couple of courses of CMU that looks really strange in a framing view without the concrete blocks visible. Ideally you would assign the things you want to show in a framing view as framing but that just leads you into a huge mess. I think I ended up making a duplicate that I could put on it's own layer which could be turned on and off as necessary. Yes, and another situation is when you use stepped pony walls for a walkout basement foundation and end up with solid 2x walls in 3d framing view, or no wall with the foundation wall layer turned off. I'm sure there are workarounds but I haven't taken the time to try, and I haven't embraced the Floor Level 1 basement method at this point. Link to comment Share on other sites More sharing options...
