Corrupted file
BillsburgChief
It was probably corrupted by your Crash mentioned in the other Thread, and typically there is no saving it , with luck you have an Auto backup in the Chief Archive Folder , which is inside your Chief Data Folder in Documents normally.
image.thumb.png.98f2d04b9fd276728db5317b3a597a62.png  image.thumb.png.5101677906830b38eb2ea0fb0209a9d0.png
20 hours ago, BillsburgChief said:
Does anyone know what would cause this?
If Chief ever crashes, as in you get a prompt saying “fatal error bla bla” but are still able to move around in your plan then be careful not to hit save.
If you do then that file will not open again and will display the message you just posted.
You’ll have to go to a prior archived file.
