BlackDiamond Posted January 5, 2023 Share Posted January 5, 2023 I'm not sure when this happened because it used to work..... but, when I launch my ray trace assistant, the dialog box doesn't come up. I use dual monitors and have closed all other programs to make sure it's not hiding anywhere. I can tab and return enough to finally get my curser back but can't access the assistant itself. Any ideas? Thanks.... Link to comment Share on other sites More sharing options...
Chopsaw Posted January 5, 2023 Share Posted January 5, 2023 (edited) I am not even sure if a toolbar reset would fix that but you could try if there is nothing to loose, but first I would maybe change your "Save Dialog Size and Position" to "Never" and do a restart to see if that works. Is there any chance you last used that with a different display configuration ? Thanks DB "I would bet that "reset dialog sizes" brings it back." Not sure why I missed that..... See Below Edited January 6, 2023 by Chopsaw Link to comment Share on other sites More sharing options...
DBCooper Posted January 5, 2023 Share Posted January 5, 2023 I would bet that "reset dialog sizes" brings it back. If not, then I would try "side windows", "toolbars", "message boxes"... And if none of that worked, I would reset all preferences as a last ditch effort. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 6, 2023 Share Posted January 6, 2023 22 hours ago, BlackDiamond said: I'm not sure when this happened because it used to work..... but, when I launch my ray trace assistant, the dialog box doesn't come up. I use dual monitors and have closed all other programs to make sure it's not hiding anywhere. I can tab and return enough to finally get my curser back but can't access the assistant itself. Any ideas? Thanks.... If you're on a Windows 10 machine, you can either: -Right click down on the taskbar and select either Cascade Windows or Show Windows Stacked to access off-screen windows. -Hold down the Windows key and use the arrow keys to reposition and dock the window to any given edge of your screen. Link to comment Share on other sites More sharing options...
BlackDiamond Posted January 6, 2023 Author Share Posted January 6, 2023 15 hours ago, Chopsaw said: I am not even sure if a toolbar reset would fix that but you could try if there is nothing to loose, but first I would maybe change your "Save Dialog Size and Position" to "Never" and do a restart to see if that works. Is there any chance you last used that with a different display configuration ? Thanks DB "I would bet that "reset dialog sizes" brings it back." Not sure why I missed that..... See Below I use a laptop and a larger monitor. Your reference to display configuration helped. I had my larger monitor set up as the main display which may have caused the problem. I just now reset my laptop to be the main display and the dialog box now appears. I'm not sure how you "reset dialog sizes". Would that allow me to keep my larger monitor as the main one? Link to comment Share on other sites More sharing options...
Chopsaw Posted January 6, 2023 Share Posted January 6, 2023 2 hours ago, BlackDiamond said: I'm not sure how you "reset dialog sizes". Would that allow me to keep my larger monitor as the main one? Yes that would most likely work. Just be aware that it resets position and size so you may have some tinkering to do to get things back the way you like them depending on how many adjustments you have made from the default setup. Preferences > Reset Options > Reset Dialog Sizes. Link to comment Share on other sites More sharing options...
