mrhoseindanesh Posted January 4, 2023 Share Posted January 4, 2023 hi..render is compeletly black with some shining points(it seems like that)what is the problem?? Link to comment Share on other sites More sharing options...
imodel Posted January 4, 2023 Share Posted January 4, 2023 Hello. More info please. 1 Link to comment Share on other sites More sharing options...
TeaTime Posted January 4, 2023 Share Posted January 4, 2023 Looks like a job for Tech Support. Probably your graphics card, might just need to download new drivers. 1 1 Link to comment Share on other sites More sharing options...
mrhoseindanesh Posted January 4, 2023 Author Share Posted January 4, 2023 it never happened before...my chief is x7 16gb ram 2g asus graphic i5 9600k i added model pic Link to comment Share on other sites More sharing options...
Chopsaw Posted January 5, 2023 Share Posted January 5, 2023 1 hour ago, mrhoseindanesh said: 16gb ram 2g asus graphic i5 9600k Would that possibly be a laptop setup ? Check to see what graphics card chief is using. Preferences > Render > Video Card Status Something may have caused that to change to using the integrated video driver rather than your 2 GB Video Card. 1 Link to comment Share on other sites More sharing options...
mrhoseindanesh Posted January 5, 2023 Author Share Posted January 5, 2023 thanks sir...no it is pc.but i didnt buy new graphic card because prices are too high here.any way this problem never happened before just happened in this project.think this pic is what you need Link to comment Share on other sites More sharing options...
Chopsaw Posted January 5, 2023 Share Posted January 5, 2023 25 minutes ago, mrhoseindanesh said: thanks sir...no it is pc.but i didnt buy new graphic card because prices are too high here.any way this problem never happened before just happened in this project.think this pic is what you need The 2 GB card should be adequate since you are running X7 so have a look through this trouble shooting article and see if any of the suggestions work for your setup. https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html#RenderPref Is this a more detailed plan than anything you have done previously ? 1 Link to comment Share on other sites More sharing options...
mrhoseindanesh Posted January 5, 2023 Author Share Posted January 5, 2023 i updated the graphic drives but not solved yes it is a hat shop and there is many hats in this plan but i had plans like this before like cosmetics shop but didnt happened this problem Link to comment Share on other sites More sharing options...
Chopsaw Posted January 5, 2023 Share Posted January 5, 2023 47 minutes ago, mrhoseindanesh said: i updated the graphic drives but not solved How about the Render Preference Settings ? Did they make any difference ? 1 Link to comment Share on other sites More sharing options...
TeaTime Posted January 5, 2023 Share Posted January 5, 2023 18 hours ago, mrhoseindanesh said: render is compeletly black 17 hours ago, mrhoseindanesh said: i added model pic wait, so by "Render" do you mean Ray Trace? 1 Link to comment Share on other sites More sharing options...
Solution mrhoseindanesh Posted January 5, 2023 Author Solution Share Posted January 5, 2023 thanks alot guys...problem solved one object had problem...by delete it ,render is ok now i checked all objects in an isolate place and it found with several test renders Link to comment Share on other sites More sharing options...
