Chiefismeantome Posted December 8, 2022 Share Posted December 8, 2022 Hi, I'd like some guidance as to what's the best way to do the following: 1) PIC 1- This house has multiple shed rooves and I'm not sure this is how they should be drawn? I created each of them individually. Is there a way to automatically generate these rooves like shown? 2) PIC 2-I can't add the missing triangular exterior wall on top of the lower roof . Also, how can I get the shingles of the portion of that roof below to now show or be removed? 3)PIC 3 How can I make the highlited portion of the wall be just an interior wall instead of the exterior wall? I only drew it continuous so the wall goes all the way to the higher roof . 4)PIC 4- How can I get rid of that sub-roof that is on my shed roof? I don't want it, I don't even know how it sneaked in there. Here is a link to the file https://we.tl/t-wZhGlDHPaQ Thank you for your time and help! I'm really struggling here. Link to comment Share on other sites More sharing options...
SNestor Posted December 9, 2022 Share Posted December 9, 2022 There is a lot of things going on with this plan. I reset walls to default top/bottom to start and went on from there. You had some walls set to balloon...but, with your second floor and other things most of these walls should have been left to automatic...and use an attic wall above. Take a look at the attached and make any needed changes. I got the roof on...although I did it all manually. I got your cheek walls in (walls above the roof)...using "roof cuts wall at bottom". FYI - I stripped a lot of stuff out of the plan (furniture primarily) in order to get the size down. You had a bunch of imported cad lines that were adding 5mb to the file. Kruk - Edited by My Chief Skills.plan.zip Link to comment Share on other sites More sharing options...
Chiefismeantome Posted December 9, 2022 Author Share Posted December 9, 2022 Thank you, kind sir! I use Chief x12 so I can't really open it. Can you send it in that version please? I have a question. Assuming I already did a bunch of cameras work to send to layouts, if I copy your model into my model ( deleting my model, but pasting in place) will the work in the layout still be there? In other words, If I replace my model with yours ( in my original model file), will I keep the layouts? Thanks again Link to comment Share on other sites More sharing options...
Garybills Posted December 9, 2022 Share Posted December 9, 2022 I have your plan fixed in x12 if you would like to message me and we can figure out how to get the entire plan to you. Link to comment Share on other sites More sharing options...
Garybills Posted December 9, 2022 Share Posted December 9, 2022 I was able to remove your furniture and cars and get the file down small enough to attach it here. Hope you can use it. Kruk.plan Link to comment Share on other sites More sharing options...
Gawdzira Posted December 9, 2022 Share Posted December 9, 2022 Best profile name ever. Link to comment Share on other sites More sharing options...
Garybills Posted December 9, 2022 Share Posted December 9, 2022 BTW that weird roof in picture 2 was the wall had auto roof return on. It drove me crazy for a few minutes. Link to comment Share on other sites More sharing options...
