Save a file as an older version
myrtsbnye
Unfortunately no.  It is not backward compatible.
https://www.chiefarchitect.com/support/article/KB-01209/message-this-plan-cannot-be-opened.html
You would need to be running the same or newer version of what they are running.  Or on future projects, they would need to run an older version.  Once a file is saved into a newer version, it cannot go back.
Hope that helps.
No sorry that is not possible with the entire plan file.  The best you could do is export a PDF or .dwg file for a 2D trace over situation.
Perhaps the project would make the upgrade worthwhile for you.
Also this to consider:
For future reference, there may be a time saver in exporting the newer X-14 plan to CAD.
The CAD import can then be brought to life in a previous version w/ the "CAD to Walls" tool.
It's not perfect, but it works fairly well.
There's a dated tutorial on the web by a fellow user which helps explain...
