blayman Posted November 27, 2022 Share Posted November 27, 2022 Recently, last week my computer crashed. Lucky for me it is a slow time for work, but i've gotten a new HD installed and thought this would be a piece of cake. But no when it rains it pours. I have an Nvidia graphics and they no longer support this. I started looking at the responses on chief talk and i see it has been several years they stopped supporting it. I never had any problems over the years so I thought it would just take off and I'd be back drawing in no time. WRONG again! I'm running a Laptop MSI QE72 2QD Apache Pro computer with I NVIDIA GTX 960 0M graphics. and from the looks of talk abut the Nvidia upgrades on here I'm lost and need a lot of help. I really would appreciate any help available (short of buying a new computer) as I'm computer illeriate when it comes to the inside workings of the computer. Thank you Bill Layman Link to comment Share on other sites More sharing options...
Chopsaw Posted November 27, 2022 Share Posted November 27, 2022 On 11/27/2022 at 5:25 PM, blayman said: I really would appreciate any help available (short of buying a new computer) Expand Pretty sure you will not be able to run anything 3D in X14 with a GTX 960. You may need to roll back to X13 and try that for now. Not much good for your existing X14 plan files but if you are between projects that might work. I believe you will need a 10 series card for X14 and if you want to use the RTRT then it needs to be an RTX card preferably a 3070 or better. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 27, 2022 Share Posted November 27, 2022 Also check what shader model your card supports as you might even encounter issues with x13. https://www.chiefarchitect.com/support/article/KB-03146/identifying-the-shader-model-of-your-graphics-card-in-windows.html Link to comment Share on other sites More sharing options...
Kbird1 Posted November 27, 2022 Share Posted November 27, 2022 On 11/27/2022 at 5:25 PM, blayman said: Nvidia upgrades on here I'm lost and need a lot of help. Expand 1st thing you check is to see if the Laptop is using the Nvidia card or not in Chief? If not look at tis old post of mine from 2020 https://chieftalk.chiefarchitect.com/topic/29075-making-chief-use-your-nvidia-graphics-card-if-needed/?tab=comments#comment-248117 then you should try turning off GPU Raytracing in Preferences...... but it seems your Laptop only has 2GB of VRAM ( Video Memory ) , https://www.msi.com/Laptop/GE72-2QD-Apache-Pro/Specification https://www.techpowerup.com/gpu-specs/geforce-gtx-960m.c2635 Chief recommends at least 4GB nowadays but that doesn't mean it won't run, but you haven't actually said what the Issue is either or what the Error message says etc.? Though you may have run into the known incompatibility of some DX12 cards with Shader 6 capabilities not having support for a certain subset of DX12 capabilities known as "Extended formats TypedUAVLoad" that the new Chief Lighting engine (x13 on ) now uses .... NVIDIA GeForce 700 - 900 Series Graphics Cards Products & Versions Affected: Chief Architect X13 and newer, Home Designer 2022 and newer Platform: Windows Description: Some graphics cards, such as the NVIDIA 700 series, may support shader model 6, but may be lacking a critical feature called "Extended formats TypedUAVLoad". If a graphics card does not support this feature the card will not function with newer versions of Chief Architect software. Information on determining if your graphics card supports this feature is available HERE. <<< LINK Solution: If you have another computer, check to see if it meets the system requirements. Contact Chief Architect for alternative solutions. Link to comment Share on other sites More sharing options...
blayman Posted November 28, 2022 Author Share Posted November 28, 2022 Thanks to all for the assistance. Looks like I need to go back to my repair people and see about a new driver or live with using X12, the newest version that I can get to work. Thanks Again Bill Layman Link to comment Share on other sites More sharing options...
Kbird1 Posted November 28, 2022 Share Posted November 28, 2022 On 11/28/2022 at 2:07 PM, blayman said: Thanks to all for the assistance. Looks like I need to go back to my repair people and see about a new driver or live with using X12, the newest version that I can get to work. Thanks Again Bill Layman Expand A driver won't help if your Videocard has the problem above unfortunately, running the DirectX Capabilities Tool linked above should tell you. More here too.......... https://www.chiefarchitect.com/support/article/KB-03146/identifying-the-shader-model-of-your-graphics-card-in-windows.html Mick. Link to comment Share on other sites More sharing options...
RobUSMC Posted November 30, 2022 Share Posted November 30, 2022 Quote Expand I spoke to tech support today about the GTX 960M and he said it would rum X-14 but may struggle with heavy rendering but dont be surprised with more X-14 updates it may stop working. Link to comment Share on other sites More sharing options...
