buzartiano Posted November 11, 2022 Share Posted November 11, 2022 Anyone know how to make exterior vinyl fluted corner boards? 5 1/2" wide both sides? Thanks in advance Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 11, 2022 Share Posted November 11, 2022 It would be pretty easy if Chief allowed us to pick a Molding Shape but currently the only shape is just a rectangle. For now the only option to get something like that is by creating a CAD Detail. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 11, 2022 Share Posted November 11, 2022 Same way you would do it when auto corner boards don't work but a little more effort involved to create the fluted profile. Polyline solid is my method. Personally I would not worry about the unseen parts of the profile or the cad detail if you can provide the manufactures code and color in a note. Link to comment Share on other sites More sharing options...
glennw Posted November 11, 2022 Share Posted November 11, 2022 Or, you could draw the shape with cad and then save to the library. Then use a Molding Polyline using your new molding. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 11, 2022 Share Posted November 11, 2022 1 hour ago, glennw said: Then use a Molding Polyline using your new molding. The thing I don't like about moldings for a situation like that is there is no 2D representation, without independently placing a molding profile ? Perhaps create the molding profile so it can be kept in the library then drop it in place and convert to a Polyline Solid or in X14 a 3D Solid. Link to comment Share on other sites More sharing options...
imodel Posted November 11, 2022 Share Posted November 11, 2022 I would use a slab. I noticed a 3D Solid has a major lag in plan view with just one copy on my machine. I have blocked this so it could be added to the library. To use: place, unblock, edit if desired, copy, paste, point to point into position. Fluted Corner Board.calibz 1 Link to comment Share on other sites More sharing options...
