hauzstudios Posted October 22, 2022 Share Posted October 22, 2022 Hi everybody, I have a problem creating an edge profile for an apron sink cabinet countertop. I can do it for all other cabinets except where the apron sink is, it doesn't let me. Is it even possible? I'm currently using X14. Attached is the picture of how it comes out. Don't know how to round the countertop with the edge profile. Your help would be much appreciated! Thank you! Carla Link to comment Share on other sites More sharing options...
DBCooper Posted October 22, 2022 Share Posted October 22, 2022 Have you tried making a custom countertop? You can make it any shape you want and then turn the molding on/off on any edges. 1 Link to comment Share on other sites More sharing options...
scottharris Posted October 22, 2022 Share Posted October 22, 2022 This support article discusses apron sinks; there’s also a link to the video in the article. Sounds like the custom countertop may solve your request if I understand correctly what you are trying to accomplish. 1 Link to comment Share on other sites More sharing options...
hauzstudios Posted October 22, 2022 Author Share Posted October 22, 2022 Hi everyone, thank you for your responses and help. I have tried doing a custom top which I can achieve and it solved the problem so thank you! but now the problem is I cant seem to get the apron sink correctly. I've followed video instructions exactly and it doesn't work. Once I try to remove top and resize to 34.5" cabinet then it turns like the picture attached. The sink appears lower even when I include the custom countertop it doesn't seem to place itself appropriately. Frustrated! Link to comment Share on other sites More sharing options...
hauzstudios Posted October 22, 2022 Author Share Posted October 22, 2022 1 hour ago, solver said: Your image is not clear, and it helps to say what the problems are, and how the finished cabinet and sink should look. You may need to change the sink, the cabinet, or both, but since only you know what's correct, it's impossible to make suggestions. I will suggest you work with the countertop in place. I did solve the problem thank you. It was a bit hard to work with an apron sink wish there were simpler solutions for that since I needed to add an edge profile to the countertop which made it harder. But got it, thank you! 1 Link to comment Share on other sites More sharing options...
hauzstudios Posted October 22, 2022 Author Share Posted October 22, 2022 I found the solution in this tutorial which was extremely helpful. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 22, 2022 Share Posted October 22, 2022 Nice arrangement and render. PBR? Link to comment Share on other sites More sharing options...
hauzstudios Posted November 23, 2022 Author Share Posted November 23, 2022 hi Gene I just used normal Chief ray trace and then made some color adjustments with photoshop. Link to comment Share on other sites More sharing options...
