JKEdmo Posted October 12, 2022 Share Posted October 12, 2022 Hello, Week 3 or so of my Chief journey. Going pretty well. Anyhow, been working on an as-built model with a walk-out basement. I would like to have the basement floor be concrete slab-on-grade with the wood framed walls sitting on top. It appears my wood walls are going through the slab. I'm a bit stumped as to the solution. Any help would be appreciated. I have attached the plan file. Thank you again, Jim THE MUNSON RESIDENCE - AS-BUILTS.planFetching info... Link to comment Share on other sites More sharing options...
JKEdmo Posted October 12, 2022 Author Share Posted October 12, 2022 On 10/12/2022 at 11:44 PM, solver said: Like a monolithic slab? Expand No, with a separate footing pour. Similar to this detail: Link to comment Share on other sites More sharing options...
GeneDavis Posted October 13, 2022 Share Posted October 13, 2022 To achieve this, walkout wall is modeled as a pony wall. Framed wall up, poured concrete foundation wall under. Set the junction height at the appropriate elevation. But yours is an as built. Could be anything going on down in the dirt. Link to comment Share on other sites More sharing options...
JKEdmo Posted October 13, 2022 Author Share Posted October 13, 2022 Thank you both Gene and Eric. I'll take a closer look at this in detail tomorrow. Jim Link to comment Share on other sites More sharing options...
dshall Posted October 13, 2022 Share Posted October 13, 2022 If I am not mistaken, you want the Retaining Wall on footing at one side of foundation and a mono slab footing on the opposite side. This is the reason that I believe the floor plan of the walk out basement should be on level 1 (not level 0). If the walk out basement plan is on level 1, this allows the mono slab foundation to be on level 0. Now define all footings at level 0 to be mono slab footings and the retaining wall is defined as a foundation stem wall. A bit tricky.... probably very difficult to build auto so this is a manual build. Link to comment Share on other sites More sharing options...
rlackore Posted October 13, 2022 Share Posted October 13, 2022 If I understand correctly, which is a big if: Referencing the Default Settings>Floors and Rooms>Floor Levels>Floor 0 dialog box, the basic issue is that the Absolute Elevations>Floor value needs to be coordinated with the Relative Heights>Stem Wall value. You can either: 1. Adjust the Stem Wall value: 2. Adjust the Floor value: Link to comment Share on other sites More sharing options...
GeneDavis Posted October 13, 2022 Share Posted October 13, 2022 Isolated, that walkout lower wall is looking like a 3-story house built on grade, no cellar or crawlspace under. i'd be surprised to find there's only an 8" deep footing under it. A lot of the Pacific NW has houses on piers and beam foundations. Link to comment Share on other sites More sharing options...
Solution JKEdmo Posted October 15, 2022 Author Solution Share Posted October 15, 2022 On 10/13/2022 at 1:44 PM, rlackore said: Referencing the Default Settings>Floors and Rooms>Floor Levels>Floor 0 dialog box, the basic issue is that the Absolute Elevations>Floor value needs to be coordinated with the Relative Heights>Stem Wall value. You can either: 1. Adjust the Stem Wall value: Expand Thanks everyone for the help on this. I adjusted the stem wall height and this works for my purposes. Jim Link to comment Share on other sites More sharing options...
