erpike Posted September 26, 2022 Share Posted September 26, 2022 Is there a way to set defaults for the actual program? I know how to set defaults for individual drawings (mainly focused on dimension and font). But when you open a "New Plan" is there a way to set the program defaults so that you don't have to change them on every drawing? Link to comment Share on other sites More sharing options...
GaryOhmer Posted September 26, 2022 Share Posted September 26, 2022 go to help and search profile plan Link to comment Share on other sites More sharing options...
rgardner Posted September 26, 2022 Share Posted September 26, 2022 1 hour ago, GaryOhmer said: go to help and search profile plan Template plan. Chief has global preferences which is for system preferences Separate are Plan specific settings that you save in a template plan to begin each job with. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 26, 2022 Share Posted September 26, 2022 3 hours ago, erpike said: But when you open a "New Plan" is there a way to set the program defaults so that you don't have to change them on every drawing? As the others mentioned look into saving one of your current Drawing where everything is setup as your New Plan Template. https://www.chiefarchitect.com/support/article/KB-03094/creating-custom-templates-from-existing-projects.html https://www.chiefarchitect.com/support/article/KB-00463/creating-and-using-a-plan-template.html Mick. Link to comment Share on other sites More sharing options...
