Window Rough Openings
Skip_D
Hi All
Why are my double-hung rough openings in the schedule 1/4" larger than they should be?  An Anderson 400 series d/h has a RO height that is equal to the Unit Dimension.  I therefore set my Rough Opening Bottom value to Zero.  But in the schedule it seems to add 1/4".  Any ideas?
Thanks,
Skip
X6
IF you check there is a r.o. # for top and bottom and just one number for sides, make the first one 1/4" it will say both sides, the next 2 will be 0, I use andersen's all the time with no problem.
and just as a side note and don't take this personnel because I have been doing this for over 30 years and just realized I was spelling Andersen the wrong way there is no o it is AndersEn, that is what it says on the front of the book
