PHDSarah Posted August 9, 2022 Share Posted August 9, 2022 My client is having a hard time visualizing what it will look like to use this custom stair baluster every fourth straight baluster, like shown. I want to recreate this in chief so they can see it in 3D. Does anyone of an idea of how to create a custom decorative baluster in chief and use it every fourth space? Appreciate any insight or tips! Thanks, Link to comment Share on other sites More sharing options...
Kbird1 Posted August 9, 2022 Share Posted August 9, 2022 It should be possible with a custom Railing PANEL , you will need to make both Balusters from 3D Solids and then save it as a Symbol. This KB Article should get you started with the general approach..... https://www.chiefarchitect.com/support/article/KB-02893/creating-custom-balusters-and-railing-panels.html M. https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 1 Link to comment Share on other sites More sharing options...
PHDSarah Posted August 10, 2022 Author Share Posted August 10, 2022 Kbird1, thank you for taking the time to share those links! I will give it a try. Best, Sarah Link to comment Share on other sites More sharing options...
Kbird1 Posted August 10, 2022 Share Posted August 10, 2022 2 hours ago, PHDSarah said: Kbird1, thank you for taking the time to share those links! I will give it a try. Best, Sarah You're welcome, if the Manufacturer of the baluster/spindle has DXF/DWG files that would save the CAD drawing part, you can then convert to a 3D solid and then a Symbol. Mick. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted August 10, 2022 Share Posted August 10, 2022 When I needed to do a railing that had mirrored pairs of balusters repeating along railings and down stair railings, I made a symbol of the mirrored two, and that was my "baluster." I remember at the time taking a 3D of a Winchester Model 94 30-30 from the 3D Warehouse and making THAT a baluster, also, just to show that anything done in 3D can be a baluster. The three stooges would be a good one, if you had a low poly model. You've got a 4-straight-one-patterned repeat, so that group of 5 solids is your baluster. Show us your results, please. We're anxious to see your solution. 1 Link to comment Share on other sites More sharing options...
robdyck Posted August 10, 2022 Share Posted August 10, 2022 I would find it easier to make the parts (quick and simple) then place them manually. After 20+ years I still don't know how to make this work as a symbol on a sloped railing. on a wall: on the stairs as a baluster: manual: 1 Link to comment Share on other sites More sharing options...
PHDSarah Posted August 12, 2022 Author Share Posted August 12, 2022 Thank you all for taking the time to give some direction on this! I tried a couple different approaches but found that creating each baluster separately and then creating some small panels (one decorative, one straight) then placing them manually to get the desired spacing, was the best for this instance. This is how it turned out... 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted August 12, 2022 Share Posted August 12, 2022 Well that should nicely let the Client get the right look ......... M. Link to comment Share on other sites More sharing options...
