GP202256 Posted July 28, 2022 Share Posted July 28, 2022 Can railing panels have siding on them without the siding being vertical? Link to comment Share on other sites More sharing options...
Kbird1 Posted July 28, 2022 Share Posted July 28, 2022 A Solid Railing Type will let you use a walltype with Siding rather than using a Panel Railing Type. M. 1 Link to comment Share on other sites More sharing options...
GP202256 Posted July 28, 2022 Author Share Posted July 28, 2022 12 minutes ago, Kbird1 said: A Solid Railing Type will let you use a walltype with Siding rather than using a Panel Railing Type. M. but then i loose the opening at the bottom Link to comment Share on other sites More sharing options...
GP202256 Posted July 28, 2022 Author Share Posted July 28, 2022 Link to comment Share on other sites More sharing options...
GP202256 Posted July 28, 2022 Author Share Posted July 28, 2022 I am an extreme beginner. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 28, 2022 Share Posted July 28, 2022 27 minutes ago, GP202256 said: but then i loose the opening at the bottom Ahhh Okay .... chief doesn't have one in the Library but it is quick and easy to make from a 3D solid with the siding applied , and the Solid saved to the Library as a Millwork symbol.................... here is the Plan I did it in, with the Symbol to save to your Library. MHD_Siding Railing Panel.plan PS please do your forum signature thanks, https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 Mick. 1 1 1 Link to comment Share on other sites More sharing options...
rgardner Posted July 28, 2022 Share Posted July 28, 2022 1 hour ago, Kbird1 said: Ahhh Okay .... chief doesn't have one in the Library but it is quick and easy to make from a 3D solid with the siding applied , and the Solid saved to the Library as a Millwork symbol.................... here is the Plan I did it in, with the Symbol to save to your Library. MHD_Siding Railing Panel.plan PS please do your forum signature thanks, https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 Mick. Even easier if you make a quick copy of the siding texture and rotate it 90 degrees: 1 1 Link to comment Share on other sites More sharing options...
GP202256 Posted July 28, 2022 Author Share Posted July 28, 2022 do you think i can add newel post 96" on corners? Link to comment Share on other sites More sharing options...
Kbird1 Posted July 29, 2022 Share Posted July 29, 2022 5 hours ago, GP202256 said: do you think i can add newel post 96" on corners? Not quite sure what you mean ? you can set a MAXIMUM spacing of 96" but not an exact spacing ....at least not easily automatically ... you might get close if the Deck is built on 96" modules. If you need exact placement let the Railing build Auto without Newel Posts , then add your own Posts from the Framing > Post Menu. Mick. Link to comment Share on other sites More sharing options...
tommy1 Posted July 29, 2022 Share Posted July 29, 2022 16 hours ago, rgardner said: Even easier if you make a quick copy of the siding texture and rotate it 90 degrees: I would approach this the same way as Ryan suggests. Link to comment Share on other sites More sharing options...
