Joe_Carrick Posted July 13, 2022 Share Posted July 13, 2022 The latest update makes these items miter at interior & exterior corners. This works fine if the WMR isn't cutting the surface layers of the walls. But it doesn't if the WMR cuts the surface layers. I hope CA can fix this oversite. Link to comment Share on other sites More sharing options...
rgardner Posted July 13, 2022 Share Posted July 13, 2022 25 minutes ago, Joe_Carrick said: The latest update makes these items miter at interior & exterior corners. This works fine if the WMR isn't cutting the surface layers of the walls. But it doesn't if the WMR cuts the surface layers. I hope CA can fix this oversite. Nice feature. Did you report it? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 13, 2022 Author Share Posted July 13, 2022 15 minutes ago, rgardner said: Nice feature. Did you report it? Not yet, but I will. Link to comment Share on other sites More sharing options...
BrianBeck Posted July 13, 2022 Share Posted July 13, 2022 Quote The latest update makes these items miter at interior & exterior corners. This works fine if the WMR isn't cutting the surface layers of the walls. But it doesn't if the WMR cuts the surface layers. Joe, I have not been able to reproduce this in my simple test cases. Please make sure to send an example of the issue you are having into tech support. Solver, I believe you will need to draw the regions accurately to the corner to see them miter at the corners. In your image the region is extended beyond the corner. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 13, 2022 Author Share Posted July 13, 2022 1 hour ago, BrianBeck said: Joe, I have not been able to reproduce this in my simple test cases. Please make sure to send an example of the issue you are having into tech support. Hi Brian, It appears the problem was with a plan that I had not yet saved in this version. It's working now. It would be nice if we could just pull around a corner similar to how we can draw walls and lines. 1 Link to comment Share on other sites More sharing options...
johnny Posted July 13, 2022 Share Posted July 13, 2022 Great addition to CA though. Link to comment Share on other sites More sharing options...
