Why no stair trim against wall in short upper segment?
GeneDavis
Here is the file.  https://www.dropbox.com/s/fvp1lver272br2n/Farmhouse w loft.plan?dl=0
The staircase has one long segment going to a landing, and a short two tread segment rising from the landing to the second floor.  That second floor, a loft, has a 24" deep floor structure, and the overlook and stair pulpit walls are railing walls, the railing done as 2" fir framing main layer, 1/2" sheetrock one face.  It is that wall that the short upper segment abuts at its R side, the side showing no skirt board trim.  The long lower stair segment abuts and interior floor drawn on floor 1 and Chief generated the specified skirt trim.
The staircase is drawn on floor 1 which is the only way I know to do a stairs going from floor 1 to floor 2.
Is the skirt trim not generating because the wall the second segment abuts is a floor 2 wall?  Whatever.  I'd like a solution before I go and do the p'solid workaround.
