Layout box label text size control
GeneDavis
I am stumped in X14 Premium.  Working on first set of con docs with this new release, and cannot seem to control the layout box label text size.
Admittedly, this is my first time using layout box labels.  I'd been in the habit of supressing labels and writing labels with layout text.
It seems to be set to generate 1/8" high text in the settings (see attached) but the text measures 1/4" high.  I cannot find the setting to change it.
You actually have 3 choices for Layout Box Labels:
  • Use System Layer (Layout Box Labels) - edit in the Layer Set
  • Use Object Layer (Layout Box Borders) - edit in the Layer Set
  • Use Custom Layer - edit in Defaults or for and individual Layout Box
each of which you have the option to define the text style as you wish.
and of couse if you're using a Callout you can edit the text styles for:
  • Callout Text
  • Above Line Text (including justification)
  • Below Line Text (including justification)
