kitchen bath toolbar x14 missing
jplicc
I believe it was removed from X14 for some reason.  You should be able to bring your X13 configuration forward manually though.
Have a look in:  C:\Users\User\Documents\Chief Architect Premier X13 Data\Toolbars
Then copy and paste:  Kitchen and Bath Design Configuration.toolbar
and:  Kitchen and Bath Design Configuration.png
into your X14 file.
Also check to see what you have in the way of cabinet icons:  cust_1.png   through to   cust_9.png
They will likely need to be the same in both files.
Also no harm in checking with tech support since they said they would let people know the correct procedure.
This one ?  the K+B Design Configuration?  I seem to have it but I did migrated my Toolbars from X13 ( X12 before that etc )
If CS Tips didn't hel you could also try a
1. ) Toolbar reset
and if that didn't work a
2.) Migration Reset
( if you still have X13 installed?) so the next time Chief starts it will bring over X13's toolbars.
3.) You can also do it manually , with Chief closed , just copy the Toolbars folder from the X13 Data Folder
to the X14 Data folder letting it overwrite any files already there.
Mick.
please do you Forum signature when you get a chance too........
https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662
