jplicc Posted June 13, 2022 Share Posted June 13, 2022 Any Idea how to get this back? Link to comment Share on other sites More sharing options...
Chopsaw Posted June 13, 2022 Share Posted June 13, 2022 I believe it was removed from X14 for some reason. You should be able to bring your X13 configuration forward manually though. Have a look in: C:\Users\User\Documents\Chief Architect Premier X13 Data\Toolbars Then copy and paste: Kitchen and Bath Design Configuration.toolbar and: Kitchen and Bath Design Configuration.png into your X14 file. Also check to see what you have in the way of cabinet icons: cust_1.png through to cust_9.png They will likely need to be the same in both files. Also no harm in checking with tech support since they said they would let people know the correct procedure. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 13, 2022 Share Posted June 13, 2022 This one ? the K+B Design Configuration? I seem to have it but I did migrated my Toolbars from X13 ( X12 before that etc ) If CS Tips didn't hel you could also try a 1. ) Toolbar reset and if that didn't work a 2.) Migration Reset ( if you still have X13 installed?) so the next time Chief starts it will bring over X13's toolbars. 3.) You can also do it manually , with Chief closed , just copy the Toolbars folder from the X13 Data Folder to the X14 Data folder letting it overwrite any files already there. Mick. please do you Forum signature when you get a chance too........ https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 Link to comment Share on other sites More sharing options...
DG1949 Posted June 17, 2022 Share Posted June 17, 2022 On 6/13/2022 at 5:11 PM, Kbird1 said: You can also do it manually Thank you! Great tip. Kept putting this off till now. Link to comment Share on other sites More sharing options...
