I cannot tilt a truss. Or can I?
GeneDavis
3 minutes ago, GeneDavis said:
What I might try is to draw an appropriately sized roof and ceiling below, generate the needed truss, and convert it to a symbol.  I can rotate the symbol.
So by normal do you mean the square side of the opening above the skylight ?  If so then yes I think that would be the best option.
26 minutes ago, GeneDavis said:
Works great.  See result.
Well done Gene. And yes, what you did is the only way to tilt a truss away from plumb.
I think I would have placed a beam at the ceiling level, and the trusses would then notch to sit on top of the beam. Don't forget to factor in hangers!
