3D objects not showing up in floor plan view
uhlerandcompany
1 hour ago, uhlerandcompany said:
Yes, I can turn all layers on and it still does it. If I try to draw a solid in plan view it disappears as soon as I release the mouse. It's still there because I can click on it but its invisible for some reason in plan view. Thanks for the help everyone!
Didn’t download your plan because if you can select it that means the layer is on.  Sounds like you changed your line style to the white color or an “invisible line” style.  Open the item and look at the line style panel of the dbx.
My best guess is that it happened when you imported some cad from another program.  The Import Drawing Assistant has an option to move all of the data to the origin when you import it which can help prevent this.  See picture below.
Once you have a plan that is far from the origin it can usually be moved back to the origin using the edit area tool.  Some more information can be found in this tech article:
https://www.chiefarchitect.com/support/article/KB-03124/troubleshooting-origin-error-messages.html
