Tony-209 Posted May 24, 2022 Share Posted May 24, 2022 Hey guys, I am looking to design a Portico over the front entrance, I don't want to have posts supporting it, more floating like the example, how do I go about this, I tried using a Dorma, but to no avail, any ideas? Thanks again! Link to comment Share on other sites More sharing options...
MoeGia Posted May 25, 2022 Share Posted May 25, 2022 I would use invisible walls to create a room the size of the gable roof you would like. Set the front wall as a gable and auto roofs should create the roof, or you can do it manually. Use a bracket from the library, manually placed. If desired, you can set the walls to no wall definition once you are finished with auto roofs. 1 1 Link to comment Share on other sites More sharing options...
joey_martin Posted May 25, 2022 Share Posted May 25, 2022 Maureen's method would give you that wall if auto roofs are turned on, I would just draw a roof plane and set the fascia height to match the main roof and your done. Size accordingly and add the bracket. 1 1 Link to comment Share on other sites More sharing options...
Solution rgardner Posted May 25, 2022 Solution Share Posted May 25, 2022 56 minutes ago, joey_martin said: Maureen's method would give you that wall if auto roofs are turned on Only if you leave it as a flat ceiling over the room. Either method is quite simple with this setup. Just look for Corbels for the brackets in the library. 1 Link to comment Share on other sites More sharing options...
Tony-209 Posted May 25, 2022 Author Share Posted May 25, 2022 Thank you for helping, I have just started using Chief Architect, I am a avid Revit user and Chief has helped with new home design tremendously. Thank you for your help! Tony System info: Chief Architect Premier X14 Processor Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz 2.90 GHz Installed RAM 16.0 GB (15.9 GB usable) Device ID F37D33DA-A815-4220-A07B-8C311E53A707 Product ID 00330-53359-37385-AAOEM System type 64-bit operating system, x64-based processor Pen and touch No pen or touch input is available for this display 2 x 32" HP Monitors Link to comment Share on other sites More sharing options...
Tony-209 Posted May 25, 2022 Author Share Posted May 25, 2022 Thank you Eric, it is so easy once you know, I apricate you for doing this, very helpful!! Link to comment Share on other sites More sharing options...
